hello again
the Racer is 95% complette!!!!
engine +Ignition+fuel lines is in place+TH servo and pushrod+choke pull mechanisim
( AS THE JC60 EVO IS MOUNTED SIDE WAYS RT-> IT WOULD BE RECOMNDED TO USE A TWING BOXER ENGINE INSTED!!! THAT WAY LESS WORK ON COWLING AND KEEPING THE NICE SHAPE AND FIGURE!!!
muffler and cowl are placed and cut/trimed acordingly
Rudd+Elev sevos and pushrods are in place and calibrated+Tail wheel
TX+wires+Opto cut off unit+IGI batt NIMH 2600Mah are placed.
Vertical and horizontal stab cover was removed and replaced with wite silicon pate +screws insted of CA glue as originaly!!!
need to do:
1.CG!!
2. LIPO 3000 Mah 40C location - per CG
3. on-off SW X2 -> Main+Ignition
break in and test flight....
see the pictures
