GBRJET will be set up in the usual place, next to Pirotti, and we look forward to seeing you all this year for what should be another great show.
New this year from GBRJET are:
CAT-Ultra - a 450cc super large CAT for use with those big power plants arriving from some of the main manufacturers - suitable for P400, B500F and many more over the 300N power category.
TAXI-TANK - an 800cc composite and aluminium unit, designed to add some 'bling' to your hanger. The tank is composite and cylindrical, the end plates are cnc'd aluminium plates which are anodised, these incorporate slots for keeping your feed line tidy when not in use. Rubber base to prevent damage to your jet and a range of trick fittings to allow you to seal the vent and feed pipes or add the new MagLOK 'dock' so you can use this new product as well.
MagLOK - a nifty vent system for use with any jet or prop, no fiddling with pushing tube over pipes, or screwing in connectors, this device is so simple you can literally hook up without having to see what you are doing! A clever magnetic lock draws the connecting 'probe' into the correct location and locks it shut. Fuel up and use the connection as an overflow link to your tank or the new TAXI-TANK, disconnect with a light pull and away you go. We think you will be impressed with this little device so make sure you pop over to see it working during the show.
Will post some pictures closer to the time on these.
The popular
CAT (Composite Air Trap) with be available and we are bringing much more stock this year so we should not run out! Other accessories include the
BULLET clunk,
Pro-Filler tank hardware and
Servo Docks for the most popular JR, Hitec and Futaba servos.
We hope to have a 'break-out' area where you can sit and rest your feet, chat with friends and generally chill.
This year we are co-habiting with Aerotrim, a great UK based company with a lovely range of RC jet protection bags including wing and fuselage bags and a very popular rain/dust cover product so you are never more than a few seconds away from covering up your jet in the event of a sudden cloud burst!
We aim to show and fly two jets during the show too, GBRJET's
Orion F3S all composite 2M span jet for 70-160N turbines and Steve (Aerotrim) will bring his amazing
Futura in a colour scheme which has to be one of the best out there - thanks go to Phil at Pinnacle Aviation for the paint work on both these jets which you will agree I am sure after seeing is remarkable
See you there
marcs
marcs
