Appreciate all the info, as far as the CG I will recheck that, I generally put the CG on all my planes to what the manuals suggest usually right smack in the center of the suggested range, however, I did make a change in the plane which may be the source of the problem because the CG may not be where it had been originally, and if that checks out I will try Aileron Reflex and possible drop the Prop Pitch; again I appreciate all the great Info.
