That is good news.. I am glad your wing join went well..Do you have any pics ? What size Epo grip did you purchase ? I bought a box of popsicle sticks for mixing my epo grip..They work good for metering out how much you are using .. Of course you use a different stick for each container and make sure you don't get them mixed up..I scoop out roughly what I figure I need out of one container and then get the other half from the other container with a new stick and compare to make sure they are close and then mix away with one of the sticks.....I often use the stick to apply the mix to my project ..I never reuse the sticks.. Someone told me once that the tiniest bit of catylist will contaminate your epoxy and eventually ruin it . So I try to be very carefull ..
