Shane, you’re not alone. Some of those DLE’s can be a PIA and my friend has one also. He has rebuilt the carburetor, replaced the ignition with a CH version, changed the spark plug and inspected the reeds. His problem is a little different than yours. The only thing he has not done is replace the carb with a Walbro. If nothing works for you, try changing the carb. Dan.
