Hello,
Generator for the 35% Cessna 185 Skywagon from Tmmy with Auto Pilot
For what a generator:
- We want to generate a voltage between 4.5 and 60V with maximum 30A to charge LiPo and NiMh batteries.
- The generator has to give also the power to all our systems like Autopilot, Ignition, Receiver and video system.
What have to do the generator:
Hi have to give us a voltage between 4.5 and 60V with maximum 30A
What we need:
- Brushless motor
- 3 Phase Diode Bridge Rectifier
- Regulators input 4.5-60V to 4-24V
The input from the brushless motor:
We think that a motor whit a KV between the 160 and 250KV is the best for us project.
If we take a 160KV motor with a ratio of 1:3, it's mean that if the Mintor 220 on idle have a RPM of 1000 the motor gone have a RMP of 3000 that gone give us 18.75V.
3000RMP/160KV=18.75V
So, when the engine is on idle we have in off voltage too give on the regulators.
Specification of the brushless Motor from Great Planes GPMG4805:
- Can Diameter: 3.14" (80mm)
- Can Length: 3.35" (85mm)
- Shaft Diameter: .39" (10mm)
- Mounting Space Length: 3.83" (97.3mm)
- RPM/V (kV Rating): 160
- Input Voltage: 33.3-55.5V (9-15S LiPo)
- Connector: 6mm bullet plugs
- Max. Constant Current: 135A (at 12S)
- Max. Continuous Power: 7500W
- Max. Surge Current: 150A (at 12S)
- Max. Surge Power: 8400W
- Max. Constant Watts: 7500W
- Weight: 52.2oz (1480g)
The regulators:
- Output of 12-14V for charging 4 PowerBox 4000mAh 2S LiPo batteries. We don't need balancer because the balancer is included in the PowerBox batteries. So, only a alimentation of 12-14V is necessary.
- Output of 12.4V to charging 2 batteries LiPo 3S 3000mAh 20C.
- Output of 4.8V for lights system and charging NiMh battery of 5300mAh
- Output of 4.2 to 26V for the autopilot supply.
- Output of 6V for the receiver, servos and ignition.
- Output of 9 to 16V for the video system.
The questions that we have:
- If the engine have a RPM of 5000, the Motor gone have a RPM of 15000 that gone generate 93.75V. Gone this support the Motor GPMG4805?
- Can we have 1 "3 Phase Diode Bridge Rectifier" for the complete system? We find one for 40A 1000V.
- Can we mount all the regulators in parallel after the 3 Phase Diode Bridge Rectifier?
All your comments or ideas are welcome
