Peak the high needle, then richen about 300 rpm, Then at idle, pinch the fuel line and observe what happens. The rpm should increase a small amount before the engine dies. If it's gaining a lot, your low speed is too rich, usually have to lean the low speed a good full turn from stock on low nitro fuel. My 115 needed a good turn and a half leaner over factory.
