Test the muffler/ tuned pipe pressure fitting for restriction. A fuel line restriction like a kink, dirt, too small a line, bad in-line filter or filter-clunk. A fuel tank that's too low can cause problems. loose the fuel-er valve if you have one.
PS, If you can't keep bearings in that 50 SX, scrap it, the case bearing bores had bad alignment in many of those.
