Scottrc: My Corsair is at 10.75 lb with Sierra gear and an OS 108 2s. It handles the weight just fine.
As for leaks: I use Robart tubing, valve, and air system. When looking for a leak I add a couple of air line extensions with quick connects so I can leave the wing off the fuse and see the air system tubing. I put a few drops of oil in the tubing generally using the quick connects between the fuse and wings and a couple of drops in the fill air line. Operate the retracts several times to spread the oil out, repressure it, then watch the oil bubbles move in the air system. They move towards the leak. If they move towards a pair of lines, clamp one line off. If the bubbles stop moving, the leak is in that branch.
Brian
Edit: do the leak check for gear up and gear down.
