yes i see that. it is a hardened pin that goes across. i guess you could get a new one but all you need is the pin the right length. it should have been locktited in the hole and should fit tight. find a pin or drill the same size and use a dremal cut off wheel to cut the shank end of the drill the right length. lock tite it in the hole, but make sure it is tight fit too. it won't come out................RON.
