The engine does appear to be a clone of the old Dynajet. My job as a teenager was to run the manual tire pump to move air into the engine to mix with the fuel and ultimately ignite. At that time you could get blisters from pumping that tire pump before the "WHOOMP!" came out of the tail pipe. As control line power plants they were spectacular when you finally got one started and turned it loose!
