Hi Jeti USA
My solution for my large model using Jeti is to incorporate a PB SRS Competition and twin RSats.
One of the reasons I've used the PB SRS unit is because it has a integrated duel redundant regs supplying 5.9v to the servos.
If I were to use a Jeti Central Box I could not use the 7.4-8.4v or so from li-fe or lipo packs as like most of us I have "non" HV Servos.
How would the Central Box cope with twin Regs instead of direct battery's.
I'm thinking that I could use perhaps the Max Bec or Max Bec 2 , but using two regs in parallel is usually a no no.
Mark
