So I have read a lot about strengthening up the retract mounts but what are some things you guys do once inside the wing for the rest of the wing?
I read the alummun wing tube is a few inch short so my plan is to find a wood dowl to fit inside that is 4in short on each side. Then get a wood dowl that is the same size as the tube. Then I only have to shave down 4in of of the dowl so I can extend it a little
Is sheeting the wing and adding some wood to the spar about all needed.
I guess seeing more broken wings would let you know it's weak points
