My truck runs great (No problems so far) Though I never abuse my truck anyway. But the gearing was too low, so I fitted the 2 Nemesis clutch pinion gears as they have more teeth (bigger), and This truck has the Nemesis front, rear and center diffs, cos they have larger output bearings and the front dogbone too (The plastic one would never hold up from the higher torque), so are perfect for this conversion... However. I wish that I could get larger wheels..
To finnish this truck completely I'll get the aluminium a-arms and 30mm long wheel hex extensions (I'm using 15mm ones at the moment).. Oh the choke is in the air filter now, so I can start the motor with the body on the truck..
Mike..
