Lower wings (cont)
Center wing:
I epoxied the front balsa block and sheeted the top and bottom, including the vertical sheeting along the rear. I didn't put those front partial ribs in; I just inserted the whole balsa block in the front. I noticed this area is suppose to be left open, after I noticed several pages back that the dowel hole is drilled from the inside of the center wing.
outer wings:
The servo trays were epoxied using spruce along the edges and rib capping was done. Will have to rip some 5/16" wide strips to finish off the bottom of the upper wing.
Fuse:
I cleared off the table and wing plans and put down the fuse plans.
Since a right and left fuse side is made separately, I cut the pieces at the same time so both sides will be exact (except for the diagonal braces).
The top front has a curve so two 1/4" square sticks are CA'ed together. After having everything pinned down, I just used thin CA to secure all the joints. The usual wax paper laid down to save butchering the plans.
