Tracker II Elevator Problems
I have a new Tracker II I'm attempting to setup in an old 4* 120. My issue revolves around the elevator. The plane is setup with 2 elevator servos using a Y-harness. I read some of the issues with elevtor trims of dual elevator setups so decided to use a Y.
I'm using a Seeker II receiver with this setup. After setting up the radio I flipped on the plane. First thing I noted was that the elevator center point was way off. Had all kinds of up elevator, but full down elevator produced little movement. Manually re-centered the servo horns and problem still exists. Pulled out a Futaba radio and now the servos responded correctly although I had to adjust the horns back to where they were originally.
Thinking there was some strange programming in the Tracker, I cleared the model memory and the problems remains. Software version in the radio is 1.31. I've looked through the manual and I stumped.
Any suggestions would be appreciated.
