The little "tang" opens the fuel valve into the pressure side of the carb... if the diaphragm is barely opening the valve then there will be too little fuel in the carb to support full throttle ! Try bending that tang away from the carb body about a thirty second of an inch. that will increase the pressure of fuel in the carb. The tang is under the 4 screws. under the rubber diaphram.
