I received my 2 rolls of covering from Value Hobby. Theirs is called Neucover but I tend to think it's the same as sold by HK.
I tested on wing tip, where I always have problems.
Observations:
* The only little problem I had was getting the backing off but finally figured it out.
* It went on just fine at 250 degrees F
* Used iron and heat gun to stretch around the wing tip. Best tip I ever did.
* The white line at edge of covering after heavy stretching appears to be adhesive as I was able to remove quite easily with acetone.
* This appears to be a winner.
I will also try the HK version when next needing covering.
Gary
