The servos are easy to remove. Take a hobby knife with a # 11 blade and carefully cut around the parameter of the two servos deep enough to ensure they are separated from the foam, take care not to cut servo leads. Then use medium pressure and pull the servos from the fuselage. Re-install using any type rtv / clear rubber sealer from a tube.
