OK, back to the drawing board on the pressure tap. I don't want to go through the side of the case as the only space to do this is where the case is grooved out for the con rod to swing around in. I think this is too thin an area and may be prone to clogging. Plus as the rod swings by the tap it may induce a partial change in pulses.
