Dude, lighten up. This place is almost a ghost town since all the upgrades. What Brian said is correct, recheck your settings on the charger again. A 1C charge rate should be 3.3 amps and the cells should all read around 4.12-4.20 depending on age. The only way you will know if its the battery or charger is to try another know good battery on it. Response time is related to proper forum posting, try to be more specific with wich forum you post in, in this case Batteries and chargers would have brought you an almost instant response.
