Originally Posted by
T_om
The filler i have used for a LONG time with foam plugs is a mix of DAP ultra light spackle and Durham's Rock Hard Water Putty. Both are available at big box stores. I get mine from the Lowe's next door to my office. The light spackle is the one that when you pick up the tub from the shelf, it feels empty.
I use a mix of about 70/30 by volume, spackle to Durham's.
Tom
It's a great mix for the white foams. I use that material as well.
However, the florists green foam as a plug can handle bondo. The cure time is minutes. The sanding is easy. If you can handle the smell. Be outdoors when using it.
Don't get me wrong, I hate bondo, but it makes short work of a plug of green florist foam.
Steve
