easy way to pull wires in plane
A few years ago I came up with idea to pull wires through wings, fueslage etc. Obtain a few feet of lamp pull chain. To this I attached a female end from a servo wire, put tape around the connector to eliminate it getting caught on ribs etc. to use, wing, put the wing tip on the floor, drop the chain in the servo mounting hole and the chain will fall through the ribs, connect the servo wire and pull through. As an improvement I use the connector that has a snap on it so it stays connected. works better than strings, dowels etc.
