Even better than reflexing the ailerons, shouldn't you adjust the strut lengths to induce the 1 deg or so of beneficial washout? That's what they are there for. Depending on the construction of the struts and how they are connected to the wing, you should be able to lengthen the rear struts slightly without too much difficulty, say with washers between the wing surface and the strut.
