RE.RC Tanks F.A.Q.
Panzer IV 's Removel of Road wheels and Return rollers.
Removal of the return rollers is achieved by first removing the outer wheel. the inner wheel then can be removed once you remove the 2mm allen screw holding it to the lower chassis that is hidden behind the return roller mounts. The removal of the road wheels is done quit the same first remove the outer wheel and then the allen holding it to the suspension arms.
