Hi if you want your diff to run much better I have some info for you as I did this with most all my open diff tamiyas and they run much better.
I used the Tamiya antiwear grease on all the moving parts on the open diffs { bevel gears and shafts and the axle with the nipple } First degrease all the parts make sure there is NO grease on them then coat them with the Tamiya anti wear grease the stuff is so sticky it works wonders on any open diff!!
Hope this helps.
Originally Posted by
860Crawler
Went out in the snow today. The freely spinning diff is pretty much useless to try and get traction, lots of donuts! After a few jumps a ball stud unscrewed from the servo saver, oops!
