Originally Posted by
apereira
Adrian,
For the Accuracy, did you get the Hatori 833? and from where? Naruke? I need one for my Acuracy as the standard will not fit as you know.
Regards
I've one but I am not using it on the bipe, since I have extra 821 with me. The 821 will fit with the YS header with room to spare, as long as you install them correctly. However, if you're not sure, then use the 831, since it's slightly shorter & lighter.
Adrian
