Zonker, Had a chance to try bumping up the pw on the start fuel, it just blowes more smoke and goes into "ignition fail".
Juan, I previously turned down start kero thinking the same thing, cooling off igniter too much but that didn't help. Then bumped up the voltage from 6.2 to
7v and that didn't help....
Eric, i'll write down the settings tomorrow and post them here. I took off the fuel line from the pump y that went to the "K" start selanoid and capped it then
plugged in propane to the "k" solenoid and set ECU to Gas Auto and the engine started first time. So engine runs fine, just would like to have it Kero start.
Thanks guys,
Arnold
