I already have $650 worth the engines and will most likely spend another $650 or better for the BIG center engine.
I have gotten the whole center section clamped up on my cradle / jig and I'm heading back down to start to glue the top half.
I'll use med CA w/ a thin tip and be very careful not to glue it to the jig this way I'll be able to invert the center section.
On to my reconfigured jig this will hold it while I mount the booms.
The aft section wasn't as bad as I first thought and I'll cut the flat sections off the the wing rib tips while it's together then sand it to my lines getting the angle just right.
Bruce
