Yes on the bottom of the CARF Viper between the tail fins. I just took the box's mount, cut it to fit between the fins, and only used 6 servo hex top screws. I tested it on the first flight with the camera's plastic hard case to make sure it wouldn't come off, then the second flight, which is posted now, with the camera in the clear hard plastic container mount.
