Couldn't agree with you more there, CP. I bought it off E-Bay for a song, not realizing it was one of Fox's best offerings. Needle valve was screwed up by someone trying to sharpen it so it leaks like a sieve, no throttle control. However there's enough of an end at the spray bar I could put a remote needle like Fox's universal NVA. That would also get the needle out of harms way, snapped off in a nose over. It's got like new compression. Head screws are chewed up, looks like someone used the wrong screw driver tip, but I could easily file it off from the side, exposed between the cooling fins. But if it ain't broke, there's no need to fix. That would be down the road.
Unmuffled on the P-40 it ought to be a hoot to fly.
