That sounds like a very good price and I'm sure you will enjoy this project.
I would equip it with HS 65 servos.
A Hayes 2 oz tank and Sullivan brand small silicone fuel line. I would run it on crankcase pressure, even if you have to rig your own tap. I've never tried to install a tap fitting on a MK 1, but unless you are familiar with using latex bladder tanks, it is well worth the time to install a pressure tap. I've entered through a mounting lug with intersecting holes, then plugged off the unwanted penetrations with aluminum wire pressed in to the access hole. Size your penetration for 3/32" brass tubing as a press in fit..or use a threaded #4-40 tap fitting.
The venturi ID should be 5/32" if running pressure at high rpm potential.
Not sure about the current trend of onboard battery choice for a pair of servos.
I've had nothing but good results with the Spektrum park flyer RX, but I'm not up to date on all the best options for small radio gear.
