The elevation motor has to be connected to the RX 18. You can either connect them directly to the RX18 or to the yellow and brown wire I have circled. Do the same kind of thing you did when you joined the Blue wire. Pull the yellow and brown wire from the harness and connect them directly to the wire you have in your hand. As long as those wires in your hand are going directly to the elevation motor
