Lunchbox Developed Problems - Advice Please
Hi, I'm hoping someone can give me some advice on my LB which seems to have developed some weird problems..Basically the following:
- the car has been running fine until the weekend when all of a sudden the car seemed to be stuck in fwd so much so that I had to adjust the trim down about 30% to get to stay still. So then I adjusted this new setting to neutral turned it back on seemed fine and then it started going backwards so I had to adjust the trim to stay fwds to get it to stay still again.
- holding the car in my hands if I hit the throttle to 100% it accelerates for a split second then goes dead, then accelerates then goes dead again and again and again etc. Like its very very jerky. I tried to run it outside and nada.
- I charged the battery two days ago and it kicking out 6.5 volts, so I stuck it on my fast charger for 5 mins and now back to 7.2.
ok now even weirder having just topped the battery up it run find fwd on centred trim but wont go backwards!!!!!!
Anyone got any ideas ?
