EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
http://www.rcuniverse.com/forum/m_7100376/tm.htm
This e-book will help you if you want to broaden your knowledge of electric.
Looks like you got a great recommendation. However if you are still unsure, using a motor selection resource can be helpful too. The Electrifly system works well. I have had good experience with the Rimfire motors.
http://www.electrifly.com/powersyste...tem-index.html
The calculator will let you vary the prop size, flight character, weight and other parameters.
