RE: Which gear to use for the Tsunami from RCATSYSTEMS?
Hi,
Because the wing is thin and of laminar flow, it requires some smaller retracts. I found that Spring Aire #303 worked really well for fitting into the wing.
An OS 91 is probably possible. I flew the prototypes with Webra 1.20 two strokes and 1.20 four strokes. Granted, on the 1.20 model, the fuselage utilized an entirely different layup since the motor was larger than normal.
The kit is has a fuselage that includes a molded scoop and vertical fin/rudder. This eliminates some build time. The extra time in making the model and laying it up this way saves time for the builder.
