Originally Posted by
aeajr
Just got two FrSky FASST receivers from Aloft. Put one in my 3.4M Supra and took it to an Eastern Soaring League contest. Worked just fine!
I flew my 2M Poly Pulsar all last season with the little 4 channel FrSky FASST receiver. My eyes will give out, before the receiver is out of range
The 4 channel FrSky was a perfect choice since I needed 4 channels, but needed to be linked in MULTI mode so I could set up failsafe settings on all channel to de-thermalize in case there is a problem.
Why anyone would bother dealing with HK when you can buy from a US based distributor that will actually be there if you do have a problem.
Pete
