I sure hope someone can help with this: I purchased a second hand Comp-ARF airframe at a fly-in. It's a nice clean Extra 330. The seller had removed most of the hardware, including the switches. So, the fuse has been cut for three switches. Seller told me heavy duty JR switches were installed. Wrong. All the JR switches are too small. The cut-out measures 15mm x 35mm with 40mm center to center on the bolt holes. I printed the Fromeco Badger mounting diagram and it seems to be a perfect fit. But, Fromeco is about the most expensive switch you can get and I need three of them. If I have to go that route, I will, but I am hoping to find an alternative. Does anyone know of another switch that size?
Tony
