A few more pictures of the wing assembly and the elevator mounting.
As my elevator tube had a lot of play in the fuse 5mm up and down on the elevator tip I decided to glue the tube into the fuse. Also the elevator mounting had to be modified as the incident pin had to much play I glued a play wood plate with the right size hole inside the fuse. Also I used a 3mm screw to hold the elevator form the inside the fuse this works fine for me as I not take the elevator always off, only when I need to service the servo.
Wing alined
Retract mounted
Wing glued together again!
Back wing screw too long and block not in the right place!
