Moving slowly forward...
The portion of the fuse below the wing will eventually have to be cut away so I completed this step now while I can see the bulkheads. I left a small bit uncut to keep the structure intact for finish assembly and sanding. Once the fuse is almost complete just a few small cuts and the wing saddle and fuse portion under the wing should just fall away.
I say should...
W
