with engines and batteries and electronics your probably around 5-6 lbs... use eCalc, and start looking at thrust numbers from different setups... you'll need ~4-5lbs of thrust which would give you 2-2.5lbs of thrust per unit... which seems to be right in the range of 64mm fans from the quick look I took...
