RCU Forums - View Single Post - Magnum xls 46 new engine
Old 04-25-2014, 05:57 AM
aspeed
aspeed's Avatar
The RC combat guys use the XLS .25, with great success. Some guys put a little dab of silicone on every conceivable joint that could leak. The screws that hold the carb on, the O ring area where the carb is mounted, under the nut that holds in the needle valve, everywhere. Likely the muffler pressure fitting would be a good spot, as well as the joint on the muffler.
