Originally Posted by
madanna67
once you have the correct measurement for the shaft, mark the shaft and cut it with some type of grinder with a cutoff wheel. I just use a 4 1/2 angle grinder. I have also used a die grinder as well. don't forget to cut the shaft long enough so that you have a 1/4 inch gap between the strut bushing and prop drive dog.
Thanks very much, I have heard some folk silver solder the section where the cut is to be made than cut once it is soldered, sounds like a sound plan.
