RCU Forums - View Single Post - Setting up a trailer for planes and hauling things?
Old 05-03-2014, 12:37 PM
flejter1
flejter1's Avatar
acdii,
I have a 16' tandem axle that rides pretty smooth. Beware of the heat build up!! That was my major concern living in sunny CA but I know it still gets hot in IL. On an 85* day it would reach over 110* inside with the doors closed. I installed 2-14" roof vents that dropped it down to 100*. I then installed 2-7" radiator fans (40.00 from EBAY) in the floor to suck cool air in from the bottom of the trailer forcing hot air out the roof vents. It now stays only a few * above outside temp. I installed an Interstate deep cycle marine battery, alarm system, a 100W solar panel (I bought on EBAY for $159.00), I installed a rack system that you can walk past the 1 side as it is easier to load bigger planes without having to go around the front to grab it while someone holds it from the rear. I also used 2" upholstery foam for the planes to sit on and absorb bouncing. I also installed 4- 30" 12V LED interior lights that take little to no power to run. My panel will keep up with running 2 fans all day, full time alarm system and a 500W power inverter and lights at night. I also gave it a little wrap job!!
ID:	1992191   Click image for larger version
ID:	1992192   Click image for larger version
ID:	1992193   Click image for larger version
ID:	1992196   Click image for larger version
ID:	1992199   Click image for larger version
