Originally Posted by
triumphman49
Hey Bicyclemonkey,
Was wondering which servo you show mounted? Throttle?? Love those adjustable arms, and have used them a lot - but mostly on 40 sz planes .
I think that one's going to be the rudder servo. I've got a HS-625 for the elevator.
I got the holes drilled in the side of the fuse for the pushrod housings.
They will be sanded flush with the fuse so all you'll see is the 4-40 rod.
Here's a close up.
I used a 3/16" brass tube that I sharpened on the end since it cuts cleaner holes than a drill bit.
