VincentJ;
Thanks for the reply, you say it's not the lightest, I would assume that Monokote/Ultrakote is the lightest, I'm also assuming that if you didn't Primer Solatex, it would be lighter than Glassing? I'm interested in painting a Warbird to avoid using shiny Plastic Films, without going through all the work of Glassing; Solartex seems like a great alternative.
Another quick question, does Solartex wrinkle like Monokote/Ultrakote when the plane is left in the sun?
As far as strength; it seems that if ARFs are sold and already covered with Monokote/Ultrakote and perform well without falling apart, than Solartex would be sufficient and provides a method to be able to paint your bird the scheme you want without the work of glassing?
