Originally Posted by
Jeremy_H
This is a big ol thing
If you get the glue in thread thing again, take a suitable bolt and put a hacksaw cut in the thread end, straight down the bolt. When facing the end file the left side of the bolt on each side, that forms a little tool that can be used to clean out threads if you don't have a tap to suit. Drill out the blocked thread with a drill that suits the core diameter (diameter of the bolt across the bottoms or root of the threads) first if you can.
like a home made tap, good idea and I'll certainly keep it in mind the next time for sure. The glue oozed out for a whole day, not a pretty sight. Thanks
