Originally Posted by
jlsimon
Granpooba, I stumbled across this page when asking the same question. I used Crochet thread from Walmart and picked up the carpet tape at Lowes. Only real tip I can give is it works best when you set up the piece only as long as you need to span your particular area. If you have a wing chord that's 14", make the piece 15". Too long and it becomes very unwieldy and the cross cutting the strips is a pain. There's a trick to picking a strip up and sticking the tape down so it doesn't twist on you and it will twist. But it works quite well and you're able to move along quite rapidly once you got the process down.
http://www.rcscalebuilder.com/Tutori...ng/default.htm
Thank you for the advise. It is only about a 10 minute consuming process, right ? LOL
