+1 for Jetmech05.
you can also run masking tape around the wing on both sides of the joint so any excess epoxy runs into the tape and not the covering.
(of course, the simplest answer is to glue the wing halves together before covering the wing
) obviously that won't work on a pre covered (arf) wing.
