Originally Posted by
Vettster
Hey Kingtech experts.. I hope you can shed some light as to why all of a sudden there are large yellow flames coming from the exhaust pipe and it is glowing red hot!! It eventually spools up and the tail cools down. This happen quit suddenly over the last 3 starts. First start was just a bit of flames... second start there was no mistaking the flames and took longer to spool. Third start took very long to spool and produced flames about 1.5 feet long. Unfortunately my GSU was not with me so no reading are available. Once fully spooled up it performed the same in the air. Seems to be a ramping issue
Any thoughts? What can I do to correct this?
Thanks!
Ps... This is on Diesel with Shell 560. 20c 10v battery
Turbine wheel rubbing? Distortion of the aft EGV causes localized rubbing, this slows acceleration artificially and the ECU over compensates on pump voltage. Once everything heats up the rubbing goes away. Does it do it on a second (immediate) start with a hot turbine?
